Old 28th May 2017, 07:14 PM
Well those are being sold by our sponsor so give them a call and ask, they will DEFINITELY know.
That said, I don't understand the question, those look like normal door inserts to me and I thought they were all the same (apart from painted vs fake veneer as noted).
Finally the set linked too looks a bit flaky on the front passenger switch panel.
What exactly do you want, I have several spare bits of that type in beige plastic that could be repainted? I definitely have the switch panels and probably the bottom shells too.
Edit: Ah, I see what you mean now! Just looked at the listing again.
The ones I have, which are from a VERY LATE FL D2 have a single top section/moulding for both the switch surround and grab handle hole. Then you just have the bottom piece that feeds up and joins it, so 2 parts per door, not 3!
