Possible voodoo
Making progress with the electrical gremlins thanks to smart a8parts folks (fixed my gps antenna, etc). Last thing I'm chasing is the "doors open". Took the latch out of the PF door and was looking and checked the switch, which is good. I have the door window carrier out, and the switch only, connected to the wiring, in my hand. I found that if I manually close the switch, it will probably show all doors except the drivers door as open. But, if I rock just a little in the drivers seat it will make the door indicator read as those three doors closed unless I let go of the switch. Wiring looks fine back in the hinge area, etc. Could this be some leveling sensor or something? Going to go drive the car and see how it acts. Any thoughts appreciated. Yeah, went for drive and all doors but drivers door are intermittent open/closed at the same time... all controlled by the frnt pass door switch?
