Old 20th June 2018, 07:10 AM
Method should be identical - The C6 RS6 ceramic and steel rear discs are the same dimensions, so if the desire (or budget) strikes, you can happily swap between the two and its been done a number of times to my knowledge.
Ceramic discs have higher temperature tolerant calipers though, so you can fit steel discs to ceramic calipers, but not vice versa strictly speaking....
