The problem with performance LPG systems is the ration of gaseous LPG to air that enters the cylinder. The more gaseous LPG there is (needed for power) the less oxygen there is as it is displaced by the LPG.
This is not such a big problem with petrol as the volume is not such a big issue.
To get big power out of LPG you either have to use F.I. or an LPI system which inject LPG in it's liquid form just above the inlet valve with the phase change taking place in the cylinder allowing more oxygen in.
The prinz system I have is good for about 400BHP. However I am running well over that on LPG. But then I'm using N2O!
