Old 23rd November 2018, 09:36 AM
RICKY D's Avatar
RICKY D RICKY D is offline
You’ll do well with the ST units James, they’re made by KW and built to the same spec as the KW V1’s without the inox front struts. Quite a few guys in the USA run them and the reviews are all positive. The only issue people have with them, which is the same as the KW V1’s, is the rears don’t always go as low as people want.
This was when I first had them fitted. The rears are maxed out on the lowest setting approx -30mm,and the fronts down about -35mm.
This was taken about a month afterwards and the fronts settled down another -5mm or so, which is around -40mm overall. The rears didn’t really change. The rears are quite sensitive to road angle; however I’ve noticed that on uneven ground the rear can look +/- 10mm depending on how uneven the surface is.
2016 S5 Coupe Black Edition - Ibis White
