Old 28th June 2018, 10:18 PM
Conquistador's Avatar
VCDS creates a text file log when you change settings, so even if you didnt make a note of the coding before, if you sniff around in the VCDS program directories you should find an audit trail.....?
Trouble is I've used VCDS 12.12 on so many laptops, it won't be the same one I originally did it on
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
