I dried out the fuse box, sprayed som electronic spray on there, replaced all the fuses and even the J329 relay which feeds the ABS unit and a bunch of other things. It's the terminal 15 relay. Pump is still running. Maybe there's a short circuit in the module or something.
It has fixed a bunch of other things though. Like the steering wheel adjustment when you turn on/off the ignition, the child lock for the rear windows etc. But I need to find the source of the leak. Are there any drain holes around there that could be clogged?
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU
