Old 18th April 2018, 02:03 PM
Originally Posted by Alex C View Post
Thread bump!
I’m having trouble getting rid of the service due reminder using VAGCOM. I pressed the SRI reset button and it seemed to cycle through and reset values but 2 starts later the reminder pops up again.
Do I need to go in and enter some values manually?
Car is a 2008 MY 4.2 tdi
Cheers!
You shouldn't need to any values as the Reset will change the values it needs to.
However, sometimes it doesn't seem to work!
But if you run the VCDS SRI function, even if you don't change anything, VCDS stores the current values in the VCDS Debug folder. See an example from my 3.0 TDi attached.
If you could look at yours and enter it here, we can probably help you ...
Julian
