Old 22nd January 2009, 09:56 PM
A8 Doc A8 Doc is offline
Default Tuning the 4.2 Litre Petrol ECU
You can download Lemmiwinks from Here!!
Again you need a VAGCOM serial compatible cable although you do not use VAGCOM!
You can tune various parts of the ECU from here. This is NOT a remap, just altering various settings to achieve a more smoother ride.
I can help with the settings, though this is at your own risk and meant for people who already under the principals of tuning. Therefore this is purely a Lemmiwinks guide.
Channel 6 learning adaptation by making it faster can vastly improve performance, though will use more fuel. Simply as the car will respond quicker to a spirited drive, not like a wafty big cruiser....
I suggest full monitoring of knock sensors etc. whilst tuning the rest of the car!!!
Ch01 : Idle Speed Offset
Adjust idle RPM level
- Higher number: increase idle rpm
- Lower number: decrease idle rpm
Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
-This channel adjusts a fuel enrichment under load
-Modulates Throttle Response
Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
-This channel adjusts a fuel enrichment term coming off the gas or decelerating.
Ch04 : Start Up Fuel Enrich
Amount of fuel on any start ups?
- Higher number: enrich the mix
- Lower number: lean out the mix
Ch05 : Warm Up fuel Enrich
Amount of fuel on start ups E.G. on the first start in the morning?
Ch06 : Lambda Regulation
Controls how fast ECU adapts:
- Higher number: faster adaptation
- Lower number: slower adaptation
Ch07 : Additive Offset To Speed Limiter
Controls speed limiter in increments ok 1km/hr
Ch08 : Secondary Fuel Tweak
It adjust gain on the injectors responce
- Higher number will increase the injector responce (smooths the ride)
- Lower number will decrease injector responce (decrease backfires)
Ch09 : Ignition Timing Offset
Controls timing in steps of 0.75 degrees, all RPM range is altered
- Higher number advances timing
- Lower number retards timing
Ch10 : Primary Fuel Tweak
Controls fueling on run, ussually change multiplicative fuel trims
- Higher number enrich the mix
- Lower number lean out the mix
Ch11 : Unused
Unused
Ch12 : SEL Scaling (Turbo Cars Only)
Adjust fueling maps according to boost settings
- Higher number increase injection period for higher boost
- Lower number decrease injection period for lower boost
Ch13 : OFF OFF
Unused
Ch14 : Idle Torque Additive Offset
Controls engine load at idle
- Higher numbers: spec load at idle is increased
- Lower numbers: spec load at idle is decreased
