Gorgeous!
I'm fairly sure that chunk of stuff is just for the brake servo. The plastic piece is a suction jet pump which just helps pull a vacuum. If you've got no other vacuum powered stuff then you should be able to just blank off both ports.
The manifold changeover valve obviously uses vacuum, but iirc that takes its vac feed from the front of the manifold. The 40V does anyway. Not 100% on the 32V though.
Perfect, Thanks for your reply.
That's more or less what I was thinking, a few of the hoses are quite badly split so think I'll try blanking them off first. Once I get it running I'll probably just play about with it and see how it runs with it blanked off.
Yeah 32v seems the same, smaller vac line straight off the front so that should be ok.
Thanks again Alan
