Originally Posted by Adrian E
Check the load index of the tyres you have on the 18s now. If they were over-specced that 'may' result in a harsher ride. Don't go below the spec for the car in terms of load index, however. Some tyre designs are more compliant, if the tyre manufacturer wants to make them that way. From memory Dunlop tend to be quite forgiving.
I wouldn't go down to 16s. It'll look daft on such a big car, and as mentioned if they're designed for vans due to the size it is VERY likely they will have a high load index and actually be harsher on ride than the 18s!
That is something I haven't considered. I think ill run these tyres to the end of their life and just try and buy something same size but softer instead of trying to fix something that isn't really broke.. thanks!
