Old 26th August 2016, 07:53 PM
damtom85 damtom85 is offline
Originally Posted by Joe2.0E View Post
My 2011 3.0TDI can be quite rough when cold, most noticeable when selecting reverse. I have had the ATF changed and it didnt make any difference.
By comparison my old 6 speed D3 was smoother when cold but nothing as "Clever" in terms of seamless/fast changes you get on the D4.
thanks for reply guys, my Gmail app wasn't updating emails and I thought nobody reply.
like Joe2 I do experience rough changes when cold, I had ATF changed, but before I did that I had new software updated by audi. I'm thinking to do one more time ATF change and maybe ask Audi to do adaptation, reset everything in transmission ecu. so basically transmission will start learning from beginning. Or maybe someone on this forum knows how to do that through Vcds?
question to Joe2 - do you know what type ATF did garage use when they changed for you? my used according to specification by manufacturer but I think they should use proper ZF lifeguard 8. Next time I will use that one.
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
