I run a nuheat thermal store, which works brilliantly, albeit a departure from typical domestic installs.
It basically a giant hot water cyclinder, but full of central heating water.
Boiler runs on a standard thermostat to keep it topped up to temp as required. Also has inputs for green technologies, solar panels etc.
Then, your heating just draws off the hot water as required via the normal CH pumps.
HW is mains pressure, but heated on demand via coils inside the thermalstore, giving instant, endless hot water.
Much more efficient for dribbling out bits of heat here and there as the boiler only need kick in occasionally to blast things back up to temp. Designed with underfloor heating in mind, but equally useful for rads.
I bought mine second hand, installed it about 6/7 years ago now and its been great.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
