Old 1st June 2020, 12:08 AM
Audifan Audifan is offline
69x2.5mm for the top one under the cap, 112x2.0 for the larger one in the pump body.
Thanks MikkiJayne!
Here is a picture of the top half (on the left in this pic) of the fuel pump assembly which I'm referring to. MikkiJayne, the pump body you mention is this same one I'm referring to as fuel pump assembly? I just want to make sure before I place a order for the o-ring.
I'm guessing these will work? this is the large o-ring and this is the smaller o-ring.
