Old 4th December 2018, 02:57 PM
My garage has been trying to get all the parts required (from TPS), ahead of my car going in for the suspension work and the new rear subframe.
Apparently, the subframe bushes were still available but there's one or two parts they're struggling to get ...
I'm told they require arm #10 (or should that be 10A?) and bolt #12. I assume these aren't handed (ie same for both sides)?
I believe the arm part number is 4D0 501 529H but we have no part number for the bolts.
So, are the bolts available new elsewhere, or should I risk buying used bolts?
Also, is the arm available as a Meyle HD part? And, if so, where can I order them from?
Thanks in advance
