Originally Posted by tonupkid
Should be easy to check.
Go to petrol station, read what VCDS says is in the tank then fill up at the pump. Add the VCDS and fill up figures, then compare with your tanks capacity.
I would compare the VCDS figure for the full tank against how much fuel you put in there.
The VCDS output and the trip computer probably use the same reading and there would have to be a safety factor in the reading to ensure the car doesn't actually run out of fuel.
Going the 103/99 km range may have put the tank a half litre below the safety level, which explains your 3-4 litre reading maybe?
