Old 9th March 2010, 10:25 PM
RNS-E install into the dash has halted (again) due to the impending install of a new airbag controller. The airbag controller sits on top of the transmission tunnel, and underneath the center console so I need to leave it all out to gain access....
Anyway, I've finished the audio loom off, which is a result. After running the Bluetooth and TV tuner into the boot, making my loom and running all the cables back again, there was still plenty to do.
This is where I also discovered a couple of important 'features' of the Kufantec adapter cables:
1) They dont put a wire in for the reverse pin. I'm not sure yet of the implications of this. There is plenty of chatter about the different ways that different cars use reverse either over canbus, or over the reverse pin. I dont know if the D2 generates a reverse signal over canbus, and the result of having no reverse is that whenever you go backwards, the Nav counts it as forwards, which is a double wammy as far as out-of-positioning is concerned. With this in mind, I have inserted an extra pin into my Kufantec adapter. It is pin C2 on the RNS-E, marked as RFSL and should simply be a +12 high when reverse is engaged. This can be taken off the reverse lights feed, or if you're upgrading from a factory fitted RNS-D, it will be in the multiplug connector from your RNS-D, also marked RFSL. Here is my modified cable:
2) If you dont order the cable with 'phone yes' then I suspect they dont put the pins in the adapter for use with a phone (I dont know, as I always tick this when ordering) - If you intend to install a bluetooth module at some point, then having this is handy as 3 of the crucial wires (Tel +, Tel - and Mute) will all have pins present that you can tap into. Without these, you will need to add another 3 wires to your Kufantec harness.
So, I've now installed the modified harness, hooked up reverse, connected the Tel +. Tel -, Mute & Kline for the bluetooth along with all the power and canbus requirements so its basically all there. I just need to mount it now, and actually drive the car to see if it works !!
Name:	av inputs 026.JPG
