Old 18th March 2010, 08:07 PM
Default New aerial loom goes in...
Installing the new loom was fairly straight forward. Firstly remove the D pillar trims and parcel shelf.
Two of the aerial amps are at the bottom of the screen on each side as per my previous photos and the other two are tucked up on each side like this circled in green.
Its a fairly short run to the diversity switcher circled in red on the passenger side, and from the drivers side the coax wires run along the edge of the parcel shelf as arrowed in black.
Note the extra foam layer on top of the parcel shelf for sound deadening which you only get on facelift cars and the roof airbag ignitor which is a fairly big looking beast when the covers are off....
I then run the 4 coax cables from the switcher through into the boot area and after taking them out of their original brown/green housing that wont fit this tuner, I directly insert the SMB connectors into the tuner to test...
and the result kind of speaks for itself really
I guess there cant be many D2's running RNS-E with working Audi TV Tuner too....
ID:	894   Click image for larger version
ID:	895   Click image for larger version
