I went out to the garage this afternoon to take a look at the sunroof, get my head around what's happening and where all the plugs.
I then noticed that the front left drain thingy was broken.
Closer inspection I noticed the whole front plastic section was cracked from the drain tube up to where the wind deflector motor is normally mounted.
it looks like I can remove the front section of the sun roof. Which isn't to bad if it the one from mine will fit.
I can still have a solar sun roof but how do I remove it?
Does anyone know how to remove the sun roof glass?
[center]
06 3.0TDI Quattro:
Options:
