Mm fair point about WD40. Replace 'WD40' for 'spray lube' then.
The only rubber in that assembly is in the UJ - little washers between the yoke and centre piece, and a chunk holding the column shaft in to the joint itself. If the joint is dry the washers might be able to squeak.
It sounds like an in-car noise to me rather than something mechanical outside, but thats obviously just listening to the video. Suspension arms creak when they're worn out, and power steering makes more of a howl.
