Old 21st January 2009, 10:35 PM
Default The Audi Build Sticker. A Wealth of information
Many items of equipment are fitted at the factory depending on when the car was built, and from an external appearance and drivability they can seem identical. At this point, the only real way to tell is to refer to the build sticker.
The sticker is on the inside cover of your original Audi Service booklet, and a dupliacate is stuck inside the spare wheel well. This square, white sticker has every code on that is required to work out exactly what part is needed for your '8. An example is below:
