Old 30th July 2018, 05:31 PM
I think you are talking about anti shudder valve. It only has two positions open and closed, it does not participate in airflow regulation, just cuts air supply when you turn ignition off so that you have smoother engine stop as it does not have to compress air in cylinders. Added benefit is that it eliminates possible engine run away.
