Make sure your actual drain gutters are clear, I think there is one on the rear right arch (under) also use a long bristle fine brush and some general purpose cleaner and clean all the top corners of the rear bumper when you have opened the boot lid. If that makes sense. You don’t want any water build up as that’s the cause of ingress into lights.
