Old 27th December 2017, 04:52 PM
OK when you only have one, but I have eight and four of them also have audio.
The other problem is that I am routing them through the cavity wall between the two parts of our house. By using 50mm gives me room to manipulate the plastic water pipe that I will be using as a routing and support for the cables to save them resting on the wall ties.
Thanks for the condolences, I did have tears in my eyes, but the good bit was that I could postpone the job till it gets a bit warmer.
