Old 17th March 2010, 08:16 PM
Default Sounds fishy.... Tuna
I'm more determined than ever to sort out the aerials now before I commit this RNS-E project as complete.
To recap, I'm not 100% sure that the older style TV tuner with its old pre 2001 diversity switcher etc will work properly with the RNS-E tuner. This may become more of an issue when I want to go digital, so whilst suck it and see is 1 option, I've decided the only solid solution is to retrofit the later Type B tuner aerials.....
Firstly, here is the location of the diversity switcher. I'm no expert, but I believe it basically takes the aerial input from all 4 aerials on the rear screen, selects the best signal and squirts that out to the tuner. It also supplies the audio headunit with its radio aerial feed:
I have the aquired 4 later aerial amps, but after removing my parcel shelf I was pleasantly surprised to see that I already have the same versions, which is good. Note there are 4 different aerial amps, and they are 4 different part numbers doing presumably slightly different things. All are marked TV/FM apart from one which also does AM... 2 aerial amps are at the bottom of the screen (1 either side) and there are 2 on the D pillars, again one either side. Each amp connects with a single wire to the rear screen where the actual aerial is, and in turn it has an SMB coax connector and power feed back into the audio loom....
To change over to the newer type tuner setup is easiest if I just add in the later tuner loom. The type A tuner has round push fit coax connectors and as yet I havn't been able to identify their name. the Type B tuner has instead newer fakra connectors which are an SMB connector with a fancy keyed plastic cover on. The switcher has 4 aerial amp feeds in, 4 feeds out to the TV tuner and 2 connections to the head unit. It also has a simple +12/ground power supply connector:
So, I start with an entire type B tuner loom from a D2
and I strip out the 4 coax feeds to the aerial amps (red circle), and the 4 feeds from the diversity switcher to the 2 x dual Fakra connectors for the Tv tuner in the boot (green arrow) The power connector is the same as the Type A tuner, and the aerial feed to the HU is an SMB on the type A, which will plug straight into the Type B diversity. The diversity feed is SMB too, but the wrong gender so I've ordered a fakra connector and set of crimps so will have a go at putting that single connector on.... eek.
Finally, the wide dual connectors on the Type B tuner are too wide to fit the RNS-E tuner, but changing them over should be easy. The SMB connectors inside pull out, and the plastic green/brown blocks can be bought from audi parts to fit the RNS-E tuner.... This is my plan anyway...
Tomorrow will see this loom being fitted so I can refit the parcel shelf and hopefully get the rear seats in too..
ID:	881   Click image for larger version
ID:	882   Click image for larger version
ID:	883   Click image for larger version
ID:	884   Click image for larger version
ID:	885   Click image for larger version
