If your not getting 13+ volts at the battery with the engine running you may have an alternator issue. Try checking the voltage from the + terminal on the battery and ground on the bodywork to rule out a bad connection between battery - and the body. If your still not getting 13+ V measure between the alternator and body with engine running. If you're still not getting 13+ Volts then it may be an alternator issue
. First though swap in a known good battery that has been fully charged then do the above checks.
