Taper vs radius:
This was the cause
Well spotted MJ!
Funny thing was, the brakes were behaving oddly too; more pedal travel than usual. Pumping the brake pedal would bring the pedal travel back to normal but only for a few seconds. Couldn't possibly be related to the wheel wobble, or so I thought ...
Turns out the studs had worked a bit loose because they were the wrong profile. My mechanic's theory on the brakes issue was that the discs were moving a little too, pushing the calipers back. I suspect he's right because the wheel wobble has gone and the brakes are back to normal now that we've removed the spacers.
