Old 20th March 2019, 08:46 AM
I'm not sure if wheel spacers would make any difference to towing a caravan tbh, or indeed make up for the heinous crime of towing a caravan either
On the standard 18" wheels you can fit 20mm front and rear. I favour the H&R bolt-on type:
These bolt to the hubs, then the wheel bolts to the spacer. I run these on my S8. They're not cheap (£115 per axle), but they are TÜV approved so you know they are good quality. Ebay is as good a place as any to find them.
The other alternative is a simple bolt-through spacer with longer bolts. I dislike these because they are a total pain to get the wheel on since everything tries to fall apart while you're putting the bolts in. They're cheaper, but not worth the hassle. The only time I use these is with 20" wheels because you have to do 15 front / 20 rear with those and the bolt-on spacers don't come in 15mm since the bolts would stick out.
