Old 27th August 2016, 10:59 AM
Default D2 Xenon range control wiring renewal
Hello D2 lovers. One more day, one more job.
Problem:
As your car is getting older the range control sensors attached to suspension on the left hand side of your car will start to fail.
You will purchase new sensors and remove the wheel only to discover that the wiring connector is so weak that it basically falls into pieces when you try remove it.
Another good sign of failing wiring is errors like below due to poor contact, etc. followed by a beep and a yellow headlight range control icon on your dashboard.
00774 - Level Control System Sensor; Rear Left (G76)
28-10 - Short to Plus - Intermittent
In my personal opinion Audi OEM wiring of xenon range control sensors is inadequate for what I expect to find **under** the car.
Here's how existing wiring looks on my car:
Front:
Rear:
Attempt to remove the connector will result in broken connector since old plastic is so brittle:
Solution:
Replace both front and rear connectors by installing the following kit.
(order quantity x part number)
3 x 000 979 009 EA -- repair wires, (A suffix = gold plated core contact, important for outdoor), -40C/+125C Note: Audi/TPS may only sell these in quantities of 5.
2 x 7M0 973 119 -- electric connector
2 x 4А0 906 102 -- rubber housing
6 x 357 972 740 D -- connector wire seal, yellow
6 x 3C0 972 841 -- connector cavity plug, orange
Expect to pay £50 to £60 for it.
Since repair wires will be crimped from both sides you cut them in half so you will have 3 crimped ends per connector. Then dress the wires with yellow seals as shown on picture:
Then slide green latches on connector and place wires into pins 1, 4 and 5 until they click. Unused cavities seal with orange plugs. Slide green latches back in place.
Then you need to cut off old connector and solder each of 3 wires one by one. Then insulate the area. I use 3M series super 88 insulation tape and then Certoplast cloth tape. No pictures, sorry. But this is a very basic wiring skill.
Additionally, you can put some silicone grease into rubber housing before you slide it onto connector.
End result front:
End result rear:
And front again:
Any questions -- shout
ID:	14057   Click image for larger version
ID:	14058   Click image for larger version
ID:	14059   Click image for larger version
ID:	14060   Click image for larger version
ID:	14061   Click image for larger version
ID:	14062   Click image for larger version
ID:	14063   Click image for larger version
ID:	14064   Click image for larger version
ID:	14065   Click image for larger version
