Originally Posted by Delboy
Im in the process of fitting a dashcam too, question is do you leave it connected to power all the time.
Reason I ask is mine has the option of doing parking mode so if something is seen in the camera field of view it will record any incidents in my absence.
Will the camera be ok to be left on, and will the car shut off the power supply should the battery get low?
Mine (a Transcend DrivePro 220) has parking mode too, but it uses an internal battery. I have it powered from an ignition switched supply and it automatically switches to parking mode when I key-off.
