Water pouring over your feet when cornering and usually a sloshing sound from behind the dashboard.
There is click r clips missing from the picture here so you would need the pliers to remove them properly to get the rubber elbows off.
Then it's just clean out the elbow and wet vac the part vertical connection and blow out the horizontal connection.
