Hiya
I'm not sure, to be honest. Until you get the kit from the new supplier and find out how open/limited it is to working with other kit, it's difficult to predict unless someone with the same service is on here (which if you're relying on 4G for access is unlikely!)
Whatever kit they supply, you should be able to link another router off that one but you need to be able to set the new one to bridge mode and faff about with settings I've never needed to use. Once that's working you can rely on the wifi you've already got.
How tied down is the router you're using now? Many I've played with recently that come from the ISP give you next to no control over anything beyond the most basic of settings.....
