Old 4th November 2018, 11:45 AM
First make sure the CD cable is connected in the back of the head unit.
If that end appears OK, check that power is available at that end and the far (changer) end.
There may be a fuse for the changer as well.
There are two +12V power circuits in the cable to the CD changer, one is always on (so you can load/eject CDs) and one is probably only on when the head unit is on.
Not sure if your head unit has a label showing the pins on the connector, but it's probably the same as an RNS-D for that connector and their layout can be found easily enough online.
IIRC it's an 8-pin connector with 3 parallel rows of pins - 3,2,3. The +12V pins are the central ones in the rows of 3, though which way round I don't recall.
Easy enough to test with a multimeter.
Somewhere I have the layout of the round connector at the changer end, will dig it out if you need it. Edit: Attached!
One slightly odd thing I discovered is that the documentation I found for that plug has the live/switched 12V connectors the wrong way round.
I'm also not 100% sure which way round that pin layout is, i.e. looking at the end of the loom or the plug on the CD changer itself.
But test it with a multimeter and you'll soon find out if there's +12v anywhere.
