Old 29th May 2017, 08:08 AM
HPsauce HPsauce is online now
I can't see any issues, but let me dig mine out and post some photos.
The big problem I foresee would be the old paint which is a rather thick soft almost rubbery material and would probably need removing.
Edit: Just had a look at the drivers one (the most complex) and it's one single moulding for the top section and it extends down about 4cm into the grab handle hole to meet the lower shell section that clips onto it from below. From above it looks like it may be in 2 parts due to a thin line, but it isn't.
The switches all come out easily enough, the only additional bit of painting would be the markings around the mirror folding switch.
There are 4 metal spring retaining clips on the drivers unit (outer edge) and these appear to have been sprayed the same colour as the rest.
