  #81
Old 2nd May 2017, 10:38 PM
HPsauce HPsauce is online now
video-in-motion
An interesting observation on this, I'm using the Kufatec solution which cuts the GALA feed.
With VIM enabled it stays on the video input irrespective of speed. As you would expect.
With VIM off (i.e. normal speed sensing) you get the warning message for few seconds then it reverts to another (standard) input. I've not 100% worked out the logic behind this (I haven't really tried) but mostly I end up back on the SatNav. Which is fine.
