Originally Posted by steamship
More attention to detail. Most mechanics would just bend the switch bracket out of the way to use the rivnut tool. As for the spanners, are you tri-dextrous?
It didn't even occur to me to bend the bracket
If you get the orientation of the bolt and larger nut right then both those spanners can be held with one hand while tightening the smaller nut with the other
