I'm fascinated that this different design exists and no-one has noticed it before!
It's basically the same but with the geometry turned from a flat set of parallel conducting/non-conducting tracks on a disc to cams around a cylinder, so a subtly different implementation.
So there is an extra indirect step (via the cams) in the mechanism which may, or may not, make it more reliable.
I wonder when it appeared and why and then presumably disappeared again....
Probably meant to be more reliable but cost too much more to make.
