As usual the fuel line clamps have rusted away so these will be replaced
Original fuel filter?
The fuel line rubbers will be soaked overnight in Bilt Hamber Korrosol to remove the embedded rust
Purple gloop
I put something back in!
The connector for the servotronic solenoid is easily accessible, despite Audi's assertion that they used the ridiculously fragile trailing cable to make it possible to install the rack.
Connector harness attached
I run the cable over the top of the rack out of the way, rather than underneath like the factory did where it could get cooked by the exhaust
This plastic nut used to go on the stud which is now replaced by an M6 rivnut, so I screwed some M6 threaded bar in to it to make a hybrid bolt
Works perfectly
