bolts for instrument cluster
The hex socket no 4. to undo the bolts on the instrument cluster and then it will pull forward....when you do put a towel over the top plastic part of the steering wheel as the instrument cluster might scratch it as you are fiddling to get the plugs off.
If the plugs havent been off will be some zip ties back there...patience and you will succeed.
The two can wires you want to tap into are on the green plug.
pin 21 for canbus low
pin 22 for canbus high
Good luck you are almost there!!!!!
