  #188
Old 19th August 2017, 12:59 PM
Finally got around to finishing and photographing my latest mining rig.
My aim was to make something robust, easily repeatable, stackable and (reasonably) compact. I intended it as a 4-card rig but I've squeezed a 5th card into this one for now, which is pushing it a bit on a single 1200W PSU. There's room for a second PSU though if necessary.
It's relatively portable and easy to carry (guessing it probably weighs about 15Kg). The black acrylic sheet panels give it a little protection and, along with the rear (filtered) fans, help to project most of the heat forwards to allow it to be used as a space heater.
I've also added a WiFi adaptor to enable it to be used anywhere there's a power outlet. I expected poorer performance mining over WiFi but there seems to be negligible difference compared with Ethernet. I do have 3 UniFi WAPs in the house though so that probably helps.
Name:	2017-08-19 13.03.11.jpg
ID:	16770 Click image for larger version
Name:	2017-08-19 13.03.35.jpg
ID:	16771 Click image for larger version
Name:	2017-08-19 13.03.56.jpg
ID:	16772 Click image for larger version
Name:	2017-08-19 13.05.18.jpg
Name:	2017-08-19 13.05.27.jpg
ID:	16774 Click image for larger version
Name:	2017-08-19 13.05.39.jpg
ID:	16775 Click image for larger version
Name:	2017-08-19 13.05.46.jpg
ID:	16776 Click image for larger version
Name:	2017-08-19 13.06.28.jpg
Name:	2017-08-19 13.06.49.jpg
ID:	16778 Click image for larger version
Name:	2017-08-19 13.07.05.jpg
ID:	16779 Click image for larger version
Name:	2017-08-19 13.07.36.jpg
ID:	16780 Click image for larger version
Name:	2017-08-19 13.07.49.jpg
Name:	2017-08-19 13.08.07.jpg
ID:	16782 Click image for larger version
Name:	2017-08-19 13.09.02.jpg
ID:	16783 Click image for larger version
Name:	2017-08-19 13.09.11.jpg
ID:	16784 Click image for larger version
Name:	2017-08-19 13.09.20.jpg
Name:	2017-08-19 13.09.28.jpg
ID:	16786 Click image for larger version
Name:	2017-08-19 13.09.45.jpg
ID:	16787 Click image for larger version
Name:	2017-08-19 13.10.00.jpg
ID:	16788 Click image for larger version
Name:	2017-08-19 13.10.20.jpg
Name:	2017-08-19 13.10.30.jpg
ID:	16790 Click image for larger version
Name:	2017-08-19 13.11.51.jpg
ID:	16791 Click image for larger version
Name:	2017-08-19 13.11.59.jpg
ID:	16792 Click image for larger version
Name:	2017-08-19 13.12.06.jpg
Name:	2017-08-19 13.15.26.jpg
ID:	16794 Click image for larger version
Name:	2017-08-19 13.15.59.jpg
ID:	16795 Click image for larger version
Name:	2017-08-19 13.16.19.jpg
The rig currently contains 4 x 1080 Ti cards + 1 x RX 480 ....
