Old 23rd March 2020, 09:21 AM
Elsawin has this to say about it:
Your coding is for EU4 configuration. I suspect you may need 26753 for 'vapour-pressure-critical countries'.
There's no login procedure described for coding the ECU (unusual) so you should simply be able to enter the new code in to VCDS. Remember to do both ECUs
