Old 3rd October 2023, 08:30 AM
Converter clutch then. Either the friction material is worn out or the piston seal has failed so the clutch isn't locking up properly. JPAT in Bristol can refurbish the converter for about £450 iirc, although obviously getting it out is a bit of an ordeal. It might be, with labour, that its logical to get the gearbox rebuilt while its out.
