Old 5th October 2016, 09:25 PM
So do you only need access from the front to fit them, a bit like a pop rivet?
I can envisage fitting them with the bolt in place (not fully tightened) with a tool to pull on it and compress the fixing then unscrew the bolt.
Or do you just push it in through whatever needs fixing then tighten?
