Old 20th July 2018, 12:42 PM
Not good, and hopefully not the gearbox, given that it was reconditioned. What sort of warranty did they give you? Mackies gives 3 years/100k, which might be a good point of reference, if you have to get into discussions with Driver Transmissions.
Mackies do warrant the box, but only if you get it serviced by them (annually I think?)
Most places do 12 months. Audi does 24.
Slipping, then slamming into third isn't a very good sign. Not sure why the engine is overheating - The D2 commonly suffers from a failed electric fan so many of them might overheat if you're sat in traffic a long time. It might be you're using the car in heavier traffic than usual, and its just the first time you've seen it. I suspect the overheat is an unrelated symptom, and not a difficult fix either.
