Old 14th March 2010, 07:53 PM
Default 1 Problem fixed....
After the earlier problems, I have made some progress.
The old type A tuner has a +12 ignition feed on a black/green wire. I have verified this using wiring diagrams, and a test meter so hurrah, thats a problem fixed. The last thing I really want to do is have to run another wire the full length of the car.
On another plus note, I get the chance to run the 3 x Av phonos from one side of the boot to the other. This is used to take the output from the rear seat entertainment kit into one of the AV inputs on the Audi TV tuner. This means whatever is playing in the rear, can be viewed in the front, and now I have RNS-E, not RNS-D, they are both widescreen too which is cool
I've been quite careful on these recent projects to ensure cables are insulated, fused and safe. This is no different so I take the ignition feed wire that needs to run from the old TV tuner connection on the left side to the RSE on right and I bundle that with the 3 AV connectors and bind it all up with fabric tape for safe keeping..... They can then all be run underneath the plastic boot lip trim....
