Originally Posted by A8 Ian
I do tend to suffer with undiagnosed narcolepsy so I was hoping it would be as easy as changing the steering column and coding as I have lane assist and acc and all the other toys to go with it. .. not to mention the fact you can (cough cough) adjust the steering input timings on vcds.. ie you can code it to stay on for miles on end without the need for touching the wheel every 10 seconds ... of course this is a driving aid not a form of Audi piloted driving, but certainly must form part of the foundation for it
So bottom line is I can't do it unless I change the steering rack?
You will need to make changes for sure, I suspect the rack, possibly the column and some associated electronics also - likely component protection issues - you would need to study the differences in ELSA, including the wiring diagrams to get a clear view - but in short, likely to be a big job!
Also given your suggestion of tweaking I'd worry about liability and insurance also!
