Originally Posted by hunker7
Great, thanks for that. I only have VCDS-Lite so not sure if I have access but I'll have a look at the sensor itself and adjust.
Should be OK for checking readings.
Delving back into my marathon thread about lack of power I found useful comments by MJ and many others. In summary:
Engine measuring block Group 66 in VCDS is the brake pedal.
The switch should have a value of 1000 when untouched.
A VERY LIGHT touch on the pedal (engine off) should change it to 1010 but the slightest bit more and it goes to 1011.
That sequence could be reversed by lifting off very carefully.
(Engine on and the servo makes it all happen too quickly)
