Old 4th April 2019, 07:18 PM
Markiii Markiii is offline
Default door pull retaining clip
well thats was a frustrating day, took the door panel off to figure out why the pin was dissapearing into the door when locked, only to fail on reassembly.
the belden cable that attaches to the interior door pull has it seems a tiny metal spring clip that holds it into the lever.
or should I say, did, as it fired itself across the garage never to be seen again
i'm not talking about the U shaped one that holds the cable to the door but a tiny thing thats surrounds the cable end and holds it into the rotating assembly
anyone know if these are still available or have a part number? currently the door only opens from the outside which is frustrating as you can imagine
