And tip #2 follows this...
Originally Posted by HPsauce
The tip? Tie a long piece of thin twine around the "loop" bit of the clip and add a bit of tape to stop it slipping around. Just tape it on somewhere or hold the end in your mouth.
Then, when your cramped hands lose grip, it won't disappear forever behind the engine.
Tip 2, in 3 parts!
a. Firstly, get a new clip (and O-ring) with your new sensor, just in case it disappears!
b. When extracting the clip try to attach something (sticky or string tied on) to it first as it can fly off and get lost easily (I just avoided this )
c. To reinsert more easily feed the 2 ends of the string from tip #1 through a thick, strong drinking straw and pull tight so that it sits at right angles to the end. You can then manipulate the clip into place and push it sideways with something rigid like a large flat-bladed screwdriver. Doing it this way reduced a long profanity-strewn struggle on previous attempts to about a minute of careful wiggling.
PS OEM sensor fitted and I now have a nice accurate temperature gauge and a car that starts first time.
