Old 12th April 2018, 12:27 PM
...and for some reason the switch seems to "react" to selecting reverse as if the change of the electromechanical contacts in passing between forward and reverse positions triggers the fault or, in some cases, "cures" it.
As HP says "Gear recognition signal" fault code is the usual indicator.
